Hi Everyone,
I want to perform Imagery selection so that the imagery the user selected, that imagery will be used when the website reloaded or the a new window is opened.my code is found below…
var imageryViewModels = ;
imageryViewModels.push(new Cesium.ProviderViewModel({
iconUrl : Cesium.buildModuleUrl(‘Widgets/Images/ImageryProviders/openStreetMap.png’),
tooltip : ‘OpenStreetMap (OSM) is a collaborative project to create a free editable
map of the world.\nhttp://www.openstreetmap.org’,
creationFunction : function() {
return Cesium.createOpenStreetMapImageryProvider({
url : ‘https://a.tile.openstreetmap.org/’
iconUrl : Cesium.buildModuleUrl(‘Widgets/Images/ImageryProviders/blackMarble.png’),
tooltip : ‘The lights of cities and villages trace the outlines of civilization
in this global view of the Earth at night as seen by NASA/NOAA’s Suomi NPP satellite.’,
return Cesium.createTileMapServiceImageryProvider({
url : ‘https://cesiumjs.org/blackmarble’,
credit : ‘Black Marble imagery courtesy NASA Earth Observatory’,
flipXY : true
name : ‘Natural Earth\u00a0II’,
iconUrl : Cesium.buildModuleUrl(‘Widgets/Images/ImageryProviders/naturalEarthII.png’),
tooltip : ‘Natural Earth II, darkened for contrast.\nhttp://www.naturalearthdata.com/’,
url : Cesium.buildModuleUrl(‘Assets/Textures/NaturalEarthII’)
//Create a CesiumWidget without imagery, if you haven’t already done so.
var cesiumWidget = new Cesium.CesiumWidget(‘cesiumContainer’, { imageryProvider: false });
//Finally, create the baseLayerPicker widget using our view models.
var layers = cesiumWidget.imageryLayers;
var baseLayerPicker = new Cesium.BaseLayerPicker(‘baseLayerPickerContainer’, {
globe : cesiumWidget.scene.globe,
imageryProviderViewModels : imageryViewModels
this.selectedImagery = undefined;
var selectedImageryViewModel = knockout.observable();
this._currentImageryProviders = [];
knockout.defineProperty(this, 'selectedImagery', {
get : function() {
return selectedImageryViewModel();
set : function(value) {
if (selectedImageryViewModel() === value) {
this.dropDownVisible = false;
return;
var i;
var currentImageryProviders = this._currentImageryProviders;
var currentImageryProvidersLength = currentImageryProviders.length;
var imageryLayers = this._globe.imageryLayers;
for (i = 0; i < currentImageryProvidersLength; i++) {
var layersLength = imageryLayers.length;
for ( var x = 0; x < layersLength; x++) {
var layer = imageryLayers.get(x);
if (layer.imageryProvider === currentImageryProviders[i]) {
imageryLayers.remove(layer);
break;
if (defined(value)) {
var newProviders = value.creationCommand();
if (isArray(newProviders)) {
var newProvidersLength = newProviders.length;
for (i = newProvidersLength - 1; i >= 0; i--) {
imageryLayers.addImageryProvider(newProviders[i], 0);
this._currentImageryProviders = newProviders.slice(0);
} else {
this._currentImageryProviders = [newProviders];
imageryLayers.addImageryProvider(newProviders, 0);
selectedImageryViewModel(value);
can you please help me??
Thank you
abdullah
