The issue when using ClippingCollection and Explixit Rendering
Hi all,
I am writing an application that allows user clip model. I have used Explicit Rendering to improve performance. However, when I create ClippingPlane to clip model and zoom it will throw the bug as the video below.
I realize that If I turn off Explicit Rendering then create ClippingPlane, it will work well.
I want to clip model within enable Explicit Rendering. Do you know the root core of the problem ?
This is the error message in the first video:
DeveloperError: This object was destroyed, i.e., destroy() was called.
Error
    at new DeveloperError (http://localhost:5173/node_modules/.vite/deps/cesium.js?v=70de511a:7483:11)
    at ShaderProgram.throwOnDestroyed (http://localhost:5173/node_modules/.vite/deps/cesium.js?v=70de511a:13729:11)
    at beginDraw (http://localhost:5173/node_modules/.vite/deps/cesium.js?v=70de511a:39460:17)
    at Context.draw (http://localhost:5173/node_modules/.vite/deps/cesium.js?v=70de511a:39554:3)
    at DrawCommand.execute (http://localhost:5173/node_modules/.vite/deps/cesium.js?v=70de511a:22484:11)
    at executeCommand (http://localhost:5173/node_modules/.vite/deps/cesium.js?v=70de511a:221608:15)
    at performPass (http://localhost:5173/node_modules/.vite/deps/cesium.js?v=70de511a:221800:7)
    at executeCommands2 (http://localhost:5173/node_modules/.vite/deps/cesium.js?v=70de511a:221918:5)
    at executeCommandsInViewport (http://localhost:5173/node_modules/.vite/deps/cesium.js?v=70de511a:222271:3)
    at Scene4.updateAndExecuteCommands (http://localhost:5173/node_modules/.vite/deps/cesium.js?v=70de511a:222085:5)
Sometime, It raises another error message:
TypeError: Cannot read properties of undefined (reading '_target')
    at UniformSampler.set (http://localhost:5173/node_modules/.vite/deps/cesium.js?v=70de511a:24591:21)
    at ShaderProgram._setUniforms (http://localhost:5173/node_modules/.vite/deps/cesium.js?v=70de511a:25517:17)
    at continueDraw (http://localhost:5173/node_modules/.vite/deps/cesium.js?v=70de511a:39491:17)
    at Context.draw (http://localhost:5173/node_modules/.vite/deps/cesium.js?v=70de511a:39555:3)
Hi @Hung, sorry you’re having issues rendering.
Would you be able to share a minimal Sandcastle example that reproduces the error? That will help us track it down and test later if we find a bug to fix.
Hi @jjspace ,
Apologies for my delayed response. I have found the root cause of the problem. It occurs when I enable requestRenderMode as true, set pickTranslucentDepth to true, and use the clipping feature. Please check the example: https://s.net.vn/FQlm
