hi,
I am trying to separate touch interactions into apple style touch, you can zoom, tilt and rotate but just one at the time. not much luck with disabling things in screenspaceController, rotatiation and tilt dont cleanly seperate. Can i do something mor low level?
Disable screenspace events corresponding to camera events for example?
Cesium default events:
zoom
[CameraEventType.RIGHT_DRAG, CameraEventType.WHEEL, CameraEventType.PINCH]
rotate
CameraEventType.LEFT_DRAG
tilt
Default Value: [CameraEventType.MIDDLE_DRAG,
CameraEventType.PINCH, { eventType : CameraEventType.LEFT_DRAG, modifier : KeyboardEventModifier.CTRL },
{ eventType : CameraEventType.RIGHT_DRAG, modifier : KeyboardEventModifier.CTRL }
if (type === CameraEventType.LEFT_DRAG) {
down = ScreenSpaceEventType.LEFT_DOWN;
up = ScreenSpaceEventType.LEFT_UP;
} else if (type === CameraEventType.RIGHT_DRAG) {
down = ScreenSpaceEventType.RIGHT_DOWN;
up = ScreenSpaceEventType.RIGHT_UP;
} else if (type === CameraEventType.MIDDLE_DRAG) {
down = ScreenSpaceEventType.MIDDLE_DOWN;
up = ScreenSpaceEventType.MIDDLE_UP;
