Tracked entity moves faster than non-tracked entity
Here is a reproduction of the problem, Cesium Sandcastle
If you select the slowest moving of the 3 white dots, you will notice it quickly speeds up and passes the dot closest to it. I am assuming this is a bug. Please let me know if I am missing something, or if there is a way for me to fix this issue.
Thank you for your time.
