We mitigated this issue in our application at our service that streams CZML. The actual image is modified in java and sent across the wire already rendered with a specified alpha value.
We ran into an issue where we would see, for a split second, the white background before the image is loaded onto the polygon. Is there is way to specify an initial no fill or transparent polygon?
