Can someone please tell me what’s wrong with this piece of code?
Cesium.Math.setRandomNumberSeed(1234);
var entities = viewer.entities;
var boxes = entities.add(new Cesium.Entity());
var polylines = new Cesium.PolylineCollection();
//Create the entities and assign each entity's parent to the group to which it belongs.
for (var i = 0; i < 5; ++i) {
var height = 100000.0 + (200000.0 * i);
entities.add({
parent : boxes,
position : Cesium.Cartesian3.fromDegrees(-106.0, 45.0, height),
box : {
dimensions : new Cesium.Cartesian3(90000.0, 90000.0, 90000.0),
material : Cesium.Color.fromRandom({alpha : 1.0})
entities.add({
parent : polylines,
position : Cesium.Cartesian3.fromDegrees(-86.0, 55.0, height),
polyline : {
width : new Cesium.ConstantProperty(2),
material : Cesium.Color.fromRandom({alpha : 1.0}),
followSurface : new Cesium.ConstantProperty(false)
It displays boxes at the given coordinates but when I am trying to draw a poly-line it gives this error: Uncaught TypeError: Cannot read property ‘push’ of undefined (on line 300 ofhttps://cesiumjs.org/Cesium/Source/DataSources/Entity.js)
I want something like this https://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=Custom%20DataSource.html&label=Showcases
Thanks in advance.
The crash is caused by attempting to use a PolylineCollection as the parent of an entity. You can eliminate the crash by changing line 6 to
var polylines = entities.add(new Cesium.Entity());
At which point you will need to supply positions to the PolylineGraphics object to have a line drawn.
Scott
Thank you so much.
I want a vertical line. Can you please help me with that.
Below you will find code to draw a polyline from one height to the next, similar to what you did with the boxes.
var prevHeight = 0.0;
entities.add({
parent : boxes,
box : {
entities.add({
parent : polylines,
polyline : {
positions: [
Cesium.Cartesian3.fromDegrees(-86.0, 55.0, prevHeight),
prevHeight = height;
Thank you so much! You made my day.
How can I display tooltip when I hover over the polyline?
onHover is going to be a difficult proposition because of the expense of auto picking at each pixel the mouse hovers over. You’re better off with a click event for triggering a tooltip.
I don’t see why not
you could do this in 1 of 2 ways that I can think of off the top of my head.
- Custom Canvas on Material on a single geometry
- Multiple Geometries that have their position adjusted accordingly.
If your going to be displaying charts, presumably on a billboard or overlay, I personally would recommend the canvas route.
Anyone else have an alternative or recommendation?
