Trying to Draw Polygon Using Polygon Hierarchy
Trying to draw a dynamic polygon of user clicked positions, also, rather than just clicking blindly, it would be great to figure out how to have the shape appear as it is being drawn. I have saw the Drawing on Terrain Sandcastle (https://sandcastle.cesium.com/?src=Drawing%20on%20Terrain.html) but I’m trying to extend my current functionality to be able to draw different shapes by clicking on the appropriate button, so it’s similar to the dropdown selection.
Sandcastles:
and
var scene = viewer.scene;
var handler = new Cesium.ScreenSpaceEventHandler(scene.canvas);
var drawing = false;
var selectedType = null;
var polygonPoints = ;
var tooltip = document.getElementById(‘tooltip’);
document.querySelector("#add-polygon").addEventListener(“click”, setEntity);
handler.setInputAction(function(movement) {
if (drawing) {
if (selectedType === ‘polygon’) {
moveTooltip(movement.endPosition, ‘left click to draw, right click to finish the shape’);
handler.setInputAction(function(click) {
console.log(‘point added’);
polygonPoints.push(viewer.scene.pickPosition(movement.endPosition));
finishPolygon();
}, Cesium.ScreenSpaceEventType.RIGHT_CLICK);
function setEntity() {
var type = this.dataset.type;
selectedType = type;
drawing = true;
if (type === ‘polygon’) {
polygonPoints = ;
var data = {
entity: ‘polygon’,
description: ‘test’,
addPolygon(data);
function addPolygon(data)
var polygon = {
description: data.description,
allowPicking: true,
show: true,
polygon: {
show: true,
hierarchy: getPolygonPoints,
outline: true,
outlineColor: Cesium.Color.RED,
outlineWidth: 9,
perPositionHeight: true,
material: Cesium.Color.BLUE.withAlpha(0.0)
label: {
disableDepthTestDistance: Number.POSITIVE_INFINITY,
text: data.name,
font: ‘9pt monospace’,
style: Cesium.LabelStyle.FILL_AND_OUTLINE,
outlineWidth: 2,
verticalOrigin: Cesium.VerticalOrigin.BOTTOM,
pixelOffset: new Cesium.Cartesian2(0, -10)
viewer.entities.add(polygon);
function finishPolygon()
console.log(‘finished drawing polygon’);
handler.removeInputAction(Cesium.ScreenSpaceEventType.LEFT_CLICK);
handler.removeInputAction(Cesium.ScreenSpaceEventType.RIGHT_CLICK);
// polygonPoints = ;
finishShape();
var getPolygonPoints = new Cesium.CallbackProperty(function() {
return Cesium.PolygonHierarchy(polygonPoints);
}, false);
function finishShape()
hideTooltip();
function showTooltip()
tooltip.style.display = ‘block’;
function hideTooltip()
tooltip.style.display = ‘none’;
function moveTooltip(position, message)
tooltip.innerHTML = message;
tooltip.style.left = position.x + 30 + “px”;
tooltip.style.top = position.y - 30 + “px”;
showTooltip();
Would like to implement the ability to draw shapes.
1.62, OS X Mojave and Chrome
Just out of curiosity have you looked at cesium-drawhelper: https://github.com/smills2929/cesium-drawhelper
It hasn’t been updated in a while but it does pretty much what you’re asking for. If nothing else it should offer some inspiration.
Dag
Hi Dag,
Thanks, yes I have seen the draw helper. It’s pretty cool, but like you say, hasn’t been updated in a while but in addition to the drawing I want to calculate distances and a couple of other measurements like area for polygons. It’s helpful to look at the code and I have done that, but I think my attempt is fairly similar but for some reason I just can’t get it to work.
Cheers,
Martin
Martin, I think you may already be evaluating this, but in case others stumble on this thread, the commercial Analytics SDK (which is built on top of CesiumJS) has a set of measurement and drawing tools:
https://cesium.com/ion-sdk/
It’s only available on-premise right now but we’re working on building it into the Cesium ion platform.
