what do the angles delta and beta stands for in this function
function handleZoom(
object,
startPosition,
movement,
zoomFactor,
distanceMeasure,
unitPositionDotDirection
let percentage = 1.0;
if (defined(unitPositionDotDirection)) {
percentage = CesiumMath.clamp(
Math.abs(unitPositionDotDirection),
0.25,
1.0
const diff = movement.endPosition.y - movement.startPosition.y;
// distanceMeasure should be the height above the ellipsoid.
// When approaching the surface, the zoomRate slows and stops minimumZoomDistance above it.
const approachingSurface = diff > 0;
const minHeight = approachingSurface
? object.minimumZoomDistance * percentage
: 0;
const maxHeight = object.maximumZoomDistance;
const minDistance = distanceMeasure - minHeight;
let zoomRate = zoomFactor * minDistance;
zoomRate = CesiumMath.clamp(
zoomRate,
object._minimumZoomRate,
object._maximumZoomRate
let rangeWindowRatio = diff / object._scene.canvas.clientHeight;
rangeWindowRatio = Math.min(rangeWindowRatio, object.maximumMovementRatio);
let distance = zoomRate * rangeWindowRatio;
if (
object.enableCollisionDetection ||
object.minimumZoomDistance === 0.0 ||
!defined(object._globe) // look-at mode
if (distance > 0.0 && Math.abs(distanceMeasure - minHeight) < 1.0) {
return;
if (distance < 0.0 && Math.abs(distanceMeasure - maxHeight) < 1.0) {
return;
if (distanceMeasure - distance < minHeight) {
distance = distanceMeasure - minHeight - 1.0;
} else if (distanceMeasure - distance > maxHeight) {
distance = distanceMeasure - maxHeight;
const scene = object._scene;
const camera = scene.camera;
const mode = scene.mode;
const orientation = scratchZoomViewOptions.orientation;
orientation.heading = camera.heading;
orientation.pitch = camera.pitch;
orientation.roll = camera.roll;
if (camera.frustum instanceof OrthographicFrustum) {
if (Math.abs(distance) > 0.0) {
camera.zoomIn(distance);
camera._adjustOrthographicFrustum(true);
return;
const sameStartPosition = defaultValue(
movement.inertiaEnabled,
Cartesian2.equals(startPosition, object._zoomMouseStart)
let zoomingOnVector = object._zoomingOnVector;
let rotatingZoom = object._rotatingZoom;
let pickedPosition;
if (!sameStartPosition) {
object._zoomMouseStart = Cartesian2.clone(
startPosition,
// When camera transform is set, such as tracking an entity, object._globe will be undefined, and no position should be picked
if (defined(object._globe) && mode === SceneMode.SCENE2D) {
pickedPosition = camera.getPickRay(startPosition, scratchZoomPickRay)
.origin;
pickedPosition = Cartesian3.fromElements(
pickedPosition.y,
pickedPosition.z,
pickedPosition.x
} else if (defined(object._globe)) {
pickedPosition = pickPosition(
object,
startPosition,
scratchPickCartesian
if (defined(pickedPosition)) {
object._useZoomWorldPosition = true;
object._zoomWorldPosition = Cartesian3.clone(
pickedPosition,
} else {
object._useZoomWorldPosition = false;
zoomingOnVector = object._zoomingOnVector = false;
rotatingZoom = object._rotatingZoom = false;
object._zoomingUnderground = object._cameraUnderground;
if (!object._useZoomWorldPosition) {
return;
let zoomOnVector = mode === SceneMode.COLUMBUS_VIEW;
if (camera.positionCartographic.height < 2000000) {
rotatingZoom = true;
if (!sameStartPosition || rotatingZoom) {
if (mode === SceneMode.SCENE2D) {
const worldPosition = object._zoomWorldPosition;
const endPosition = camera.position;
if (
!Cartesian3.equals(worldPosition, endPosition) &&
camera.positionCartographic.height < object._maxCoord.x * 2.0
const savedX = camera.position.x;
const direction = Cartesian3.subtract(
worldPosition,
endPosition,
scratchZoomDirection
Cartesian3.normalize(direction, direction);
const d =
(Cartesian3.distance(worldPosition, endPosition) * distance) /
(camera.getMagnitude() * 0.5);
camera.move(direction, d * 0.5);
if (
(camera.position.x < 0.0 && savedX > 0.0) ||
(camera.position.x > 0.0 && savedX < 0.0)
.origin;
pickedPosition.y,
pickedPosition.z,
pickedPosition.x
pickedPosition,
} else if (mode === SceneMode.SCENE3D) {
const cameraPositionNormal = Cartesian3.normalize(
camera.position,
scratchCameraPositionNormal
if (
object._cameraUnderground ||
object._zoomingUnderground ||
(camera.positionCartographic.height < 3000.0 &&
Math.abs(Cartesian3.dot(camera.direction, cameraPositionNormal)) <
0.6)
zoomOnVector = true;
} else {
const canvas = scene.canvas;
const centerPixel = scratchCenterPixel;
centerPixel.x = canvas.clientWidth / 2;
centerPixel.y = canvas.clientHeight / 2;
const centerPosition = pickPosition(
object,
centerPixel,
scratchCenterPosition
// If centerPosition is not defined, it means the globe does not cover the center position of screen
if (!defined(centerPosition)) {
} else if (camera.positionCartographic.height < 1000000) {
// The math in the else block assumes the camera
// points toward the earth surface, so we check it here.
// Theoretically, we should check for 90 degree, but it doesn't behave well when parallel
// to the earth surface
if (Cartesian3.dot(camera.direction, cameraPositionNormal) >= -0.5) {
} else {
const cameraPosition = scratchCameraPosition;
Cartesian3.clone(camera.position, cameraPosition);
const target = object._zoomWorldPosition;
let targetNormal = scratchTargetNormal;
targetNormal = Cartesian3.normalize(target, targetNormal);
if (Cartesian3.dot(targetNormal, cameraPositionNormal) < 0.0) {
return;
const center = scratchCenter;
const forward = scratchForwardNormal;
Cartesian3.clone(camera.direction, forward);
Cartesian3.add(
cameraPosition,
Cartesian3.multiplyByScalar(forward, 1000, scratchCartesian),
center
const positionToTarget = scratchPositionToTarget;
const positionToTargetNormal = scratchPositionToTargetNormal;
Cartesian3.subtract(target, cameraPosition, positionToTarget);
Cartesian3.normalize(positionToTarget, positionToTargetNormal);
const alphaDot = Cartesian3.dot(
cameraPositionNormal,
if (alphaDot >= 0.0) {
// We zoomed past the target, and this zoom is not valid anymore.
// This line causes the next zoom movement to pick a new starting point.
object._zoomMouseStart.x = -1;
return;
const alpha = Math.acos(-alphaDot);
const cameraDistance = Cartesian3.magnitude(cameraPosition);
const targetDistance = Cartesian3.magnitude(target);
const remainingDistance = cameraDistance - distance;
const positionToTargetDistance = Cartesian3.magnitude(
positionToTarget
const gamma = Math.asin(
CesiumMath.clamp(
(positionToTargetDistance / targetDistance) * Math.sin(alpha),
-1.0,
1.0
const delta = Math.asin(
CesiumMath.clamp(
(remainingDistance / targetDistance) * Math.sin(alpha),
-1.0,
1.0
const beta = gamma - delta + alpha;
const up = scratchCameraUpNormal;
Cartesian3.normalize(cameraPosition, up);
let right = scratchCameraRightNormal;
right = Cartesian3.cross(positionToTargetNormal, up, right);
right = Cartesian3.normalize(right, right);
Cartesian3.cross(up, right, scratchCartesian),
forward
// Calculate new position to move to
Cartesian3.normalize(center, scratchCartesian),
Cartesian3.magnitude(center) - distance,
center
Cartesian3.normalize(cameraPosition, cameraPosition);
cameraPosition,
remainingDistance,
cameraPosition
// Pan
const pMid = scratchPan;
Cartesian3.add(
up,
Math.cos(beta) - 1,
scratchCartesianTwo
forward,
Math.sin(beta),
scratchCartesianThree
scratchCartesian
remainingDistance,
pMid
Cartesian3.add(cameraPosition, pMid, cameraPosition);
Cartesian3.normalize(center, up);
forward
const cMid = scratchCenterMovement;
Cartesian3.add(
up,
Math.cos(beta) - 1,
scratchCartesianTwo
forward,
Math.sin(beta),
scratchCartesian
Cartesian3.magnitude(center),
cMid
Cartesian3.add(center, cMid, center);
// Update camera
// Set new position
Cartesian3.clone(cameraPosition, camera.position);
// Set new direction
Cartesian3.subtract(center, cameraPosition, scratchCartesian),
camera.direction
Cartesian3.clone(camera.direction, camera.direction);
// Set new right & up vectors
Cartesian3.cross(camera.direction, camera.up, camera.right);
Cartesian3.cross(camera.right, camera.direction, camera.up);
camera.setView(scratchZoomViewOptions);
return;
} else {
const positionNormal = Cartesian3.normalize(
centerPosition,
scratchPositionNormal
const pickedNormal = Cartesian3.normalize(
object._zoomWorldPosition,
scratchPickNormal
const dotProduct = Cartesian3.dot(pickedNormal, positionNormal);
if (dotProduct > 0.0 && dotProduct < 1.0) {
const angle = CesiumMath.acosClamped(dotProduct);
const axis = Cartesian3.cross(
pickedNormal,
positionNormal,
scratchZoomAxis
const denom =
Math.abs(angle) > CesiumMath.toRadians(20.0)
? camera.positionCartographic.height * 0.75
: camera.positionCartographic.height - distance;
const scalar = distance / denom;
camera.rotate(axis, angle * scalar);
object._rotatingZoom = !zoomOnVector;
if ((!sameStartPosition && zoomOnVector) || zoomingOnVector) {
let ray;
const zoomMouseStart = SceneTransforms.worldToWindowCoordinates(
scene,
scratchZoomOffset
if (
mode !== SceneMode.COLUMBUS_VIEW &&
Cartesian2.equals(startPosition, object._zoomMouseStart) &&
defined(zoomMouseStart)
ray = camera.getPickRay(zoomMouseStart, scratchZoomPickRay);
} else {
ray = camera.getPickRay(startPosition, scratchZoomPickRay);
const rayDirection = ray.direction;
if (mode === SceneMode.COLUMBUS_VIEW || mode === SceneMode.SCENE2D) {
rayDirection.y,
rayDirection.z,
rayDirection.x,
rayDirection
camera.move(rayDirection, distance);
object._zoomingOnVector = true;
} else {
if (!object._cameraUnderground) {
