I’m using Cesium for out-the-window visualization in a flight simulator. I’d like to hide/destroy the skyAtmosphere at night.
Any suggestions on how to determine if the sun has set?
Thanks, Matt.
Thanks, Matt.
We actually had some code laying around to do something close to this. Here’s a Sandcastle example that uses the camera position to determine whether the sun is visible at that location and turns on/off atmosphere. Just replace viewer.scene.camera.position with whatever position you want. Eventually, we’ll probably have some cool built in visualization for this in Cesium itself.
var transformMatrix = new Cesium.Matrix4();
var toSun = new Cesium.Cartesian3();
var toMoon = new Cesium.Cartesian3();
viewer.clock.onTick.addEventListener(function(clock) {
var position = viewer.scene.camera.position;
var up = viewer.scene.globe.ellipsoid.geodeticSurfaceNormal(position);
var time = clock.currentTime;
Cesium.Transforms.computeTemeToPseudoFixedMatrix(time, transformMatrix);
Cesium.Simon1994PlanetaryPositions.computeSunPositionInEarthInertialFrame(time, toSun);
Cesium.Matrix3.multiplyByVector(transformMatrix, toSun, toSun);
Cesium.Cartesian3.normalize(toSun, toSun);
viewer.scene.skyAtmosphere.show = Cesium.Cartesian3.dot(up, toSun) > 0.0;
Thanks!
I also found a nice little library for calculating the sun position:
https://github.com/mourner/suncalc
my code:
function updateSkyAtmosphere() {
var dateNow = Cesium.JulianDate.toDate(viewer.clock.currentTime);
var sunPos = SunCalc.getPosition(dateNow, acState.lat, acState.lng);
viewer.scene.skyAtmosphere.show = sunPos.altitude > 0;
I just tested this out yesterday and it worked great! I was trying to hack around in non-native ways, but this ended up being great.
However, i do think it’d be great to have a dynamic SkyAtmosphere property to change with sun altitude, similar to how you can do this for Atmosphere with scene.atmosphere.dynamicLighting = DynamicAtmosphereLightingType.SUNLIGHT;
I believe you guys already have something in place for Cesium Unreal, but it could be valuable for JS
