hello, i meet the error when i use postProcessStages to simulate the fog with shader, the cesium version is 1.106.1,my code is shown below:
const fog = `
float getDistance(sampler2D depthTexture, vec2 texCoords)
float depth = czm_unpackDepth(texture(depthTexture, texCoords));
if (depth == 0.0) {
return czm_infinity;
vec4 eyeCoordinate = czm_windowToEyeCoordinates(gl_FragCoord.xy, depth);
return -eyeCoordinate.z / eyeCoordinate.w;
float interpolateByDistance(vec4 nearFarScalar, float distance)
float startDistance = nearFarScalar.x;
float startValue = nearFarScalar.y;
float endDistance = nearFarScalar.z;
float endValue = nearFarScalar.w;
float t = clamp((distance - startDistance) / (endDistance - startDistance), 0.0, 1.0);
return mix(startValue, endValue, t);
vec4 alphaBlend(vec4 sourceColor, vec4 destinationColor)
return sourceColor * vec4(sourceColor.aaa, 1.0) + destinationColor * (1.0 - sourceColor.a);
uniform sampler2D colorTexture;
uniform sampler2D depthTexture;
uniform vec4 fogByDistance;
uniform vec4 fogColor;
in vec2 v_textureCoordinates;
void main(void)
float distance = getDistance(depthTexture, v_textureCoordinates);
vec4 sceneColor = texture(colorTexture, v_textureCoordinates);
float blendAmount = interpolateByDistance(fogByDistance, distance);
vec4 finalFogColor = vec4(fogColor.rgb, fogColor.a * blendAmount);
out_FragColor = alphaBlend(finalFogColor, sceneColor);
function createFogStage() {
var Fog= new Cesium.PostProcessStage({
fragmentShader: Fog
return Fog;
var collection = viewer.scene.postProcessStages;
var fog= createFogStage()
collection.add(fog)
look forward to your reply.
