I have two imageryViewModels added to the "viewer" with baseLayerPick set to false. I was able to switch to either one of them by clicking on the drop-down icon. However, I am unable to switch from one to the other by clicking another button that calls a javascript function because I want to switch them on-the-fly through code.
I've been searching this forum and the stackoverflow for a while but I could not solve it. I found many examples show how to set and switch the default imagery when constructing a viewer, but not with customized ProviderViewModel. Please see my code below (I removed my access token). Thanks in advance!
This is my HTML button: <button onclick="javascript:changeBaseLayer(1);">changeBaseLayer</button>
var imageryViewModels = ;
imageryViewModels.push(new Cesium.ProviderViewModel({
name: 'ArtilerySim Terrain',
iconUrl: Cesium.buildModuleUrl('Widgets/Images/ImageryProviders/mapboxSatellite.png'),
tooltip: 'Beautiful clear imagery',
creationFunction: function () {
return new Cesium.MapboxImageryProvider({
mapId: 'mapbox.satellite',
//Get your DigitalGlobe Maps API Access Token here: http://developer.digitalglobe.com/maps-api
accessToken: 'pk.',
credit: 'ArtilleryVision'
name: 'ArtilerySim Street Maps',
iconUrl: Cesium.buildModuleUrl('Widgets/Images/ImageryProviders/mapboxStreets.png'),
mapId: 'mapbox.streets',
accessToken: 'pk.',
baseLayerPicker: false,
terrainProvider: Cesium.createWorldTerrain(),
imageryProviderViewModels: imageryViewModels, //HQN: new with Mapbox
shouldAnimate: true,
homeButton: false,
animation: true,
timeline: true,
navigationHelpButton: false
var baseLayerPicker = new Cesium.BaseLayerPicker('baseLayerPickerContainer', {
globe: viewer.scene, // Yep, this is right
// This is the javascript function that the button calls:
function changeBaseLayer(iIndex) {
console.log(imageryViewModels[1]);
baseLayerPicker.selectedImageryProviderViewModel = imageryViewModels[iIndex];
I want to switch my customized imageryViewModel on-the-fly using Javascript.
I'm using version 1.55
