You are correct that 0,0,0 is the center of the earth.
direction is not a fixed location, but normalized vector that indicates the direction of travel. For example 0,1,0 is the +Y direction. 0,0,0 is not valid for direction since it does not have a magnitude of 1.
If you want the vector to point from the satellite to the center of earth, the origin would be position of the satellite. The direction would point towards 0,0,0.
const result = new Cartesian3();
const direction = Cartesian3.normalize(
Cartesian3.negate(position, result),
result
entity.vector = new VectorGraphics({
position,
direction
Thanks for your help! So I left out the position, it is on the entity itself. The position are SampledPositionProperty so the entity will move. Would I also need some kind of sampled direction?
It seems to be working with the following (general idea, some code removed):
const sampledProperty = new SampledProperty(Cartesian3);
sampledProperty.setInterpolationOptions({
interpolationAlgorithm: LagrangePolynomialApproximation,
interpolationDegree: 5,
// Coordinates are [Julian, Cartesian3]
for (const c of coordinates) {
Cartesian3.negate(c[1], result),
result
sampledProperty.addSample(c[0], direction);
And then set this as the direction in the VectorGraphics.
@mdc9001 I’m now trying to place xyz vector axis, similar to DebugModelMatrixPrimitive. However, I cannot get the vectors correct. Am I misunderstanding the Cartesian direction?
const zAxis = new Entity({
position: // Cartesian3 coordinates,
vector: new VectorGraphics({
color: Color.BLUE,
direction: new Cartesian3(0, 0, 1),
minimumLengthInPixels: 30,
length: 100,
You can see below that the blue arrow does not match DebugModelMatrixPrimitive blue line.
The orientation of the DebugModelMatrixPrimitive depends on the value of the matrix that was provided to the constructor. It is possible that the matrix represents a coordinate system with different axes that the global coordinate system.
Are you able to provide a full code snippet that can run a sandcastle? That will help give additional context.
You can run a version of sandcastle locally with the Cesium ion SDK. If you use npm run build and npm run start. That sandcastle will include the additional ion SDK features. If you have not seen it already there is also a example that shows using vectors.
The vector and the entity are using in different reference frames for their coordinates. This is why the +Z vector appears to point in different directions.
The entity defaults to using the NorthEastUp reference frame if orientation is not provided. This is what the DebugModelMAtrixPrimitive is showing.
The vector always uses WGS84 coordinate reference frame (per the notes in the API documentation). I can see how this can be a little confusing since other items in the entity use the entity reference frame.
