I added to my WCSTerrainProvider a mechanism allowing me to store locally the heighmap buffer with IndexedDB.
The process works as follows:
I search in IndexedDB if the requested tile is present locally.
If the tile is present then I get the heighmap buffer and I return the HeightmapTerrainData
But, if the tile is not stored locally, I submit a WCS request. If the query is executed correctly, I parse the returned geotiff and create the buffer that I store in the local database then I return the HeightmapTerrainData.
My first tests are promising.
I encounter a problem to chain correctly the 2 promises in the requestTileGeometry function:
I have to define a promise “request Tile In IndexedDB” and if this promise is rejected then I have to define a new promise “request Tile in WCS”
which gives:
Cesium.when (requestTileInIndexedDB, function (tileData) {…
return heightmapTerrainData ;
}) .otherwise (Function (evt)
var promiseGetCoverage = Cesium.loadWithXh ({url: urlGetCoverage, responseType ‘ArrayBuffer’});
Cesium.when (promiseGetCoverage, function (image) {…
return heightmapTerrainData ; }) .otherwise …
What should return the first Otherwise function ? if I return the second promise Cesium throw an issue because I do not return a heightmapTerrainData but a promise.
xlhomme
