Hi all,
I am developing an application using webpack and react. I was able to view successfully.
but I get an error when I use search params specific to the application.
how can i solve this problem.
Thank you
Webpack config =>
const path = require('path');
const HTMLWebpackPlugin = require('html-webpack-plugin');
const cesiumSource = 'node_modules/cesium/Source';
const cesiumWorkers = '../Build/Cesium/Workers';
const webpack = require('webpack');
const MiniCssExtractPlugin = require('mini-css-extract-plugin')
const TerserPlugin = require("terser-webpack-plugin");
const CopyWebpackPlugin = require('copy-webpack-plugin');
module.exports = {
entry: {
index:path.resolve(__dirname, 'src', 'index.js')
output: {
path: path.resolve(__dirname, 'dist'),
filename: "[name].bundle.js",
sourcePrefix: ''
amd: {
// Enable webpack-friendly use of require in Cesium
toUrlUndefined: true
resolve: {
alias: {
cesium: path.resolve(__dirname, cesiumSource)
mainFiles: ['module', 'index', 'Cesium'],
fallback: { https: false, zlib: false, http: false, url: false },
optimization: {
splitChunks: {
chunks: "initial",
minChunks: 1,
maxSize: 1000000,
minSize: 30000,
minimize: true,
minimizer: [
new TerserPlugin({
test: /\.js(\?.*)?$/i,
plugins: [
new HTMLWebpackPlugin({
template: path.resolve(__dirname, "src", "index.html")
new MiniCssExtractPlugin(),
new CopyWebpackPlugin({
patterns: [
{ from: path.join(cesiumSource, cesiumWorkers), to: 'Workers' },
{ from: path.join(cesiumSource, 'Assets'), to: 'Assets' },
{ from: path.join(cesiumSource, 'Widgets'), to: 'Widgets' }
new webpack.DefinePlugin({
// Define relative base path in cesium for loading assets
CESIUM_BASE_URL: JSON.stringify('/')
module: {
rules: [
test: /\.js$/,
exclude: /node_modules/,
use: {
loader: 'babel-loader',
options: {
presets: ['@babel/preset-env', '@babel/preset-react']
test: /\.(sa|sc|c)ss$/i,
//use: ['style-loader', "css-loader", "sass-loader"]
use:[MiniCssExtractPlugin.loader, 'css-loader']
test: /\.(png|gif|jpg|jpeg|xml)$/,
use: [ 'url-loader' ]
test: /\.(woff|woff2|eot|ttf|svg|otf)$/,
loader: "file-loader",
options: {
outputPath: "font",
test: /\.json5$/i,
use: ['json-loader']
