I’m having some trouble with the way GroundPrimitives and GeoJsonDataSources are represented in Firefox.
I’m using this code for adding Ground Primitives:
var pathInstance = new Cesium.GeometryInstance({
geometry: new Cesium.CorridorGeometry({
positions: positions,
width: width,
vertexFormat: Cesium.PerInstanceColorAppearance.VERTEX_FORMAT,
attributes: {
color: new Cesium.ColorGeometryInstanceAttribute.fromColor(color)
var pathPrimitive = new Cesium.GroundPrimitive({
geometryInstances: pathInstance
I’ve tried setting depthTestAgainstTerrain to false and to true, and the result is the same.
I’m using Windows 10, Firefox 49.0.2, Edge 38.14393.0.0 and Chrome 53.0.2785.143 m.
is it a known bug in Cesium? Can I do something to fix it? Thanks in advance!
Thanks for putting together that example! It renders fine for me in firefox. Maybe it’s a problem specific to your graphics card. What kind of graphics card does your computer have?
I’ve seen this before, but I’m not sure if we have an issue for it. Most likely a browser/GPU/driver problem. I know Sean can reproduce it in Chrome but not Firefox.
Camila, from your chrome GPU report, it looks like you are not actually running with the graphics card that you think you are. Chrome says that you have an Intel HD 4000. Is this a laptop? If so you are most likely running with an optimus configuration and Firefox is not triggering the switchover to the nvidia GPU. You may be able to force the nvidia card and that may resolve the problem.
Oh my, sorry, I definitely messed this up. The GPU report I posted earlier was from the wrong PC. I was accessing my remote PC via TeamViewer from my laptop and I suppose I somehow messed the screens up and posted the GPU report of my laptop (which yes, runs on Intel HD 4000 and by the way it doesn't have the Firefox issue). Here is the correct report:
Graphics Feature Status
Canvas: Hardware accelerated
Flash: Hardware accelerated
Flash Stage3D: Hardware accelerated
Flash Stage3D Baseline profile: Hardware accelerated
Compositing: Hardware accelerated
Multiple Raster Threads: Enabled
Native GpuMemoryBuffers: Software only. Hardware acceleration disabled
Rasterization: Software only. Hardware acceleration disabled
Video Decode: Hardware accelerated
Video Encode: Hardware accelerated
VPx Video Decode: Hardware accelerated
WebGL: Hardware accelerated
Driver Bug Workarounds
clear_uniforms_before_first_program_use
disable_discard_framebuffer
disable_framebuffer_cmaa
exit_on_context_lost
force_cube_complete
scalarize_vec_and_mat_constructor_args
texsubimage_faster_than_teximage
use_current_program_after_successful_link
Problems Detected
Always call glUseProgram after a successful link to avoid a driver bug: 349137
Applied Workarounds: use_current_program_after_successful_link
Some drivers are unable to reset the D3D device in the GPU process sandbox
Applied Workarounds: exit_on_context_lost
TexSubImage is faster for full uploads on ANGLE
Applied Workarounds: texsubimage_faster_than_teximage
Clear uniforms before first program use on all platforms: 124764, 349137
Applied Workarounds: clear_uniforms_before_first_program_use
Always rewrite vec/mat constructors to be consistent: 398694
Applied Workarounds: scalarize_vec_and_mat_constructor_args
ANGLE crash on glReadPixels from incomplete cube map texture: 518889
Applied Workarounds: force_cube_complete
Framebuffer discarding can hurt performance on non-tilers: 570897
Applied Workarounds: disable_discard_framebuffer
Limited enabling of Chromium GL_INTEL_framebuffer_CMAA: 535198
Applied Workarounds: disable_framebuffer_cmaa
Accelerated rasterization has been disabled, either via blacklist, about:flags or the command line.
Disabled Features: rasterization
Native GpuMemoryBuffers have been disabled, either via about:flags or command line.
Disabled Features: native_gpu_memory_buffers
Version Information
Data exported 26/10/2016, 08:05:21
Chrome version Chrome/54.0.2840.71
Operating system Windows NT 10.0.14393
Software rendering list version 11.12
Driver bug list version 9.00
ANGLE commit id 905fbdea9ef0
2D graphics backend Skia/54 a21f10dd8b19c6cb47d07d94d0a0525c16461969
Command Line Args Files (x86)\Google\Chrome\Application\chrome.exe" --flag-switches-begin --flag-switches-end
Driver Information
Initialization time 56
In-process GPU false
Sandboxed false
GPU0 VENDOR = 0x10de, DEVICE= 0x1381
Optimus false
AMD switchable false
Desktop compositing Aero Glass
Driver vendor NVIDIA
Driver version 21.21.13.6909
Driver date 8-1-2016
Pixel shader version 5.0
Vertex shader version 5.0
Max. MSAA samples 8
Machine model name
Machine model version
GL_VENDOR Google Inc.
GL_RENDERER ANGLE (NVIDIA GeForce GTX 750 Direct3D11 vs_5_0 ps_5_0)
GL_VERSION OpenGL ES 2.0 (ANGLE 2.1.0.905fbdea9ef0)
GL_EXTENSIONS GL_OES_element_index_uint GL_OES_packed_depth_stencil GL_OES_get_program_binary GL_OES_rgb8_rgba8 GL_EXT_texture_format_BGRA8888 GL_EXT_read_format_bgra GL_NV_pixel_buffer_object GL_OES_mapbuffer GL_EXT_map_buffer_range GL_EXT_color_buffer_half_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_float GL_OES_texture_float_linear GL_EXT_texture_rg GL_EXT_texture_compression_dxt1 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_OES_compressed_ETC1_RGB8_texture GL_EXT_sRGB GL_ANGLE_depth_texture GL_OES_depth32 GL_EXT_texture_storage GL_OES_texture_npot GL_EXT_draw_buffers GL_EXT_texture_filter_anisotropic GL_EXT_occlusion_query_boolean GL_NV_fence GL_EXT_disjoint_timer_query GL_EXT_robustness GL_EXT_blend_minmax GL_ANGLE_framebuffer_blit GL_ANGLE_framebuffer_multisample GL_ANGLE_instanced_arrays GL_ANGLE_pack_reverse_row_order GL_OES_standard_derivatives GL_EXT_shader_texture_lod GL_EXT_frag_depth GL_ANGLE_texture_usage GL_ANGLE_translated_shader_source GL_EXT_discard_framebuffer GL_EXT_debug_marker GL_OES_EGL_image GL_OES_EGL_image_external GL_NV_EGL_stream_consumer_external GL_EXT_unpack_subimage GL_NV_pack_subimage GL_OES_vertex_array_object GL_KHR_debug GL_ANGLE_lossy_etc_decode GL_CHROMIUM_bind_uniform_location GL_CHROMIUM_sync_query GL_CHROMIUM_copy_texture
Disabled Extensions
Window system binding vendor Google Inc. (adapter LUID: 000000000418bbe4)
Window system binding version 1.4 (ANGLE 2.1.0.905fbdea9ef0)
Window system binding extensions EGL_EXT_create_context_robustness EGL_ANGLE_d3d_share_handle_client_buffer EGL_ANGLE_surface_d3d_texture_2d_share_handle EGL_ANGLE_query_surface_pointer EGL_ANGLE_window_fixed_size EGL_ANGLE_keyed_mutex EGL_ANGLE_surface_orientation EGL_ANGLE_direct_composition EGL_NV_post_sub_buffer EGL_KHR_create_context EGL_EXT_device_query EGL_KHR_image EGL_KHR_image_base EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_get_all_proc_addresses EGL_KHR_stream EGL_KHR_stream_consumer_gltexture EGL_NV_stream_consumer_gltexture_yuv EGL_ANGLE_flexible_surface_compatibility EGL_ANGLE_stream_producer_d3d_texture_nv12
Direct rendering Yes
Reset notification strategy 0x8252
GPU process crash count 0
Compositor Information
Tile Update Mode One-copy
Partial Raster Enabled
GpuMemoryBuffers Status
ATC Software only
ATCIA Software only
DXT1 Software only
DXT5 Software only
ETC1 Software only
R_8 Software only
BGR_565 Software only
RGBA_4444 Software only
RGBX_8888 Software only
RGBA_8888 Software only
BGRX_8888 Software only
BGRA_8888 Software only
YVU_420 Software only
YUV_420_BIPLANAR Software only
UYVY_422 Software only
Diagnostics
0
b3DAccelerationEnabled true
b3DAccelerationExists true
bAGPEnabled true
bAGPExistenceValid true
bAGPExists true
bCanRenderWindow true
bDDAccelerationEnabled true
bDriverBeta false
bDriverDebug false
bDriverSigned false
bDriverSignedValid false
bNoHardware false
dwBpp 32
dwDDIVersion 12
dwHeight 1080
dwRefreshRate 60
dwWHQLLevel 0
dwWidth 1920
iAdapter 0
lDriverSize 17569488
lMiniVddSize 0
szAGPStatusEnglish Enabled
szAGPStatusLocalized Enabled
szChipType GeForce GTX 750
szD3DStatusEnglish Enabled
szD3DStatusLocalized Enabled
szDACType Integrated RAMDAC
szDDIVersionEnglish 12
szDDIVersionLocalized 12
szDDStatusEnglish Enabled
szDDStatusLocalized Enabled
szDXVAHDEnglish Supported
szDXVAModes
szDescription NVIDIA GeForce GTX 750
szDeviceId 0x1381
szDeviceIdentifier {D7B71E3E-50C1-11CF-636A-4F1618C2D835}
szDeviceName \\.\DISPLAY6
szDisplayMemoryEnglish 4095 MB
szDisplayMemoryLocalized 4095 MB
szDisplayModeEnglish 1920 x 1080 (32 bit) (60Hz)
szDisplayModeLocalized 1920 x 1080 (32 bit) (60Hz)
szDriverAssemblyVersion 21.21.13.7563
szDriverAttributes Final Retail
szDriverDateEnglish 21/10/2016 2:00:00
szDriverDateLocalized 10/21/2016 02:00:00
szDriverLanguageEnglish English
szDriverLanguageLocalized English
szDriverModelEnglish WDDM 2.1
szDriverModelLocalized WDDM 2.1
szDriverName C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_49b226e6441043f1\nvd3dumx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_49b226e6441043f1\nvwgf2umx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_49b226e6441043f1\nvwgf2umx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_49b226e6441043f1\nvwgf2umx.dll
szDriverNodeStrongName oem33.inf:0f066de3a7a02f92:Section078:21.21.13.7563:pci\ven_10de&dev_1381
szDriverSignDate Unknown
szDriverVersion 21.21.0013.7563
szKeyDeviceID Enum\PCI\VEN_10DE&DEV_1381&SUBSYS_36421458&REV_A2
szKeyDeviceKey \Registry\Machine\System\CurrentControlSet\Control\Video\{E2D26A65-21D9-4B1A-A6AF-AFBFC9232D68}\0000
szManufacturer NVIDIA
szMiniVdd unknown
szMiniVddDateEnglish Unknown
szMiniVddDateLocalized unknown
szMonitorMaxRes Unknown
szMonitorName Unknown
szNotesEnglish No problems found.
szNotesLocalized No problems found.
szOverlayEnglish Supported
szRankOfInstalledDriver 00D12001
szRegHelpText Unknown
szRevision Unknown
szRevisionId 0x00A2
szSubSysId 0x36421458
szTestResultD3D7English Not run
szTestResultD3D7Localized Not run
szTestResultD3D8English Not run
szTestResultD3D8Localized Not run
szTestResultD3D9English Not run
szTestResultD3D9Localized Not run
szTestResultDDEnglish Not run
szTestResultDDLocalized Not run
szVdd unknown
szVendorId 0x10DE
1
bAGPEnabled true
bAGPExists true
bDriverBeta false
bDriverDebug false
bDriverSigned false
bNoHardware false
dwBpp 32
dwDDIVersion 12
dwHeight 1080
dwRefreshRate 60
dwWHQLLevel 0
dwWidth 1920
iAdapter 1
lMiniVddSize 0
szDXVAModes
szDeviceId 0x1381
szDeviceName \\.\DISPLAY7
szKeyDeviceKey \Registry\Machine\System\CurrentControlSet\Control\Video\{E2D26A65-21D9-4B1A-A6AF-AFBFC9232D68}\0001
szMiniVdd unknown
szMonitorName Generic Non-PnP Monitor
szRevision Unknown
szRevisionId 0x00A2
szVdd unknown
szVendorId 0x10DE
Log Messages
[4800:5036:1025/084256:ERROR:mf_helpers.cc(12)] : Error in dxva_video_decode_accelerator_win.cc on line 1402
[4800:5036:1025/084256:ERROR:mf_helpers.cc(12)] : Error in dxva_video_decode_accelerator_win.cc on line 604
[4800:5036:1025/084256:ERROR:gpu_video_decode_accelerator.cc(365)] : HW video decode not available for profile 12
[4800:5036:1025/100724:ERROR:gles2_cmd_decoder.cc(15953)] : [.DisplayCompositor-0B3C4080]GL ERROR :GL_INVALID_OPERATION : glCreateAndConsumeTextureCHROMIUM: invalid mailbox name
[4800:5036:1025/100724:ERROR:gles2_cmd_decoder.cc(8803)] : [.DisplayCompositor-0B3C4080]RENDER WARNING: texture bound to texture unit 0 is not renderable. It maybe non-power-of-2 and have incompatible texture filtering.
[4800:5036:1025/115010:ERROR:gles2_cmd_decoder.cc(8803)] : [.Offscreen-For-WebGL-04122AA8]RENDER WARNING: texture bound to texture unit 0 is not renderable. It maybe non-power-of-2 and have incompatible texture filtering.
[4800:5036:1025/144932:ERROR:dxva_picture_buffer_win.cc(21)] : Error in dxva_picture_buffer_win.cc on line 400
[4800:5036:1025/145022:ERROR:gles2_cmd_decoder.cc(15953)] : [.DisplayCompositor-0B3C4080]GL ERROR :GL_INVALID_OPERATION : glCreateAndConsumeTextureCHROMIUM: invalid mailbox name
[4800:5036:1025/150515:ERROR:mf_helpers.cc(12)] : Error in dxva_video_decode_accelerator_win.cc on line 1402
[4800:5036:1025/150515:ERROR:mf_helpers.cc(12)] : Error in dxva_video_decode_accelerator_win.cc on line 604
[4800:5036:1025/150515:ERROR:gpu_video_decode_accelerator.cc(365)] : HW video decode not available for profile 12
GpuProcessHostUIShim: The GPU process exited normally. Everything is okay.
[4800:5036:1025/200345:ERROR:gles2_cmd_decoder.cc(14158)] : Context lost because SwapBuffers failed.
[4800:5036:1025/200345:ERROR:gles2_cmd_decoder.cc(14517)] : Onscreen context lost via ARB/EXT_robustness. Reset status = GL_UNKNOWN_CONTEXT_RESET_KHR
[4800:5036:1025/200345:ERROR:gles2_cmd_decoder.cc(5071)] : Error: 5 for Command kPostSubBufferCHROMIUM
[4800:5036:1025/200345:ERROR:gpu_channel_manager.cc(224)] : Exiting GPU process because some drivers cannot recover from problems.
