Why Arcgis tile terrain make my globe is super slow ??
When i use ArcGIS Tiled Terrain my globe is being super slow.
Super low frame almost 2~3 fps.
But just change terrain to Cesium terrain. there are no problem
Why this difference happen??
2.1 - Arcgis tiledterrain Code
terrainProvider: new Cesium.ArcGISTiledElevationTerrainProvider({
    url: 'https://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer'
2-2 . Cesium terrain Code
terrainProvider: Cesium.createWorldTerrain(),
Cesium terrain is no good resolution
it’s very rough
See image terrain invaded 3dtiles
1.62 win10 Chrome
The Arc GIS terrain tiles are slower because it produces significantly more geometry. You can see this by turning on the Cesium inspector:
viewer.extend(Cesium.viewerCesiumInspectorMixin);
And then clicking Terrain > Wireframe. Notice the Arc GIS terrain is much more dense, because it’s created from a height map, as opposed to the quantized mesh format which allows you to have highly detailed geometry without requiring a regular grid.
We are always working on improving the accuracy and quality of Cesium World Terrain - are there any particular areas you’d like to see improved?
Hi Omar.
I understand why ArcGIS terrain tiles are slower.
Our work area is Busan, Korea.
129.144821, 35.154470
129.132045, 35.154747
129.120789, 35.165601
And i found one strange.
I fix the setting of viewer terrainProvider: Cesium.createWorldTerrain().
And just switch baselayerpicker false to true. otherwise true false.
Globe loaded different terrain.
Why this happen??
Above images i attached is it’s evidence.
Actually it’s not different terrain
It’s bug.
I don’t know why this occur.
I’ve recorded the issues you’ve brought in a bug report here: https://github.com/AnalyticalGraphicsInc/cesium-ion-community/issues/170
For the last picture, can you elaborate a bit more on what the issue is, or provide the lat/lon for it?
Hi Omar
It was .gif file that record bug but it’s not working.
So i uploaded video at youtube
You can watch here
And i wrote lon and lat at above reply
Thank you
Just to update this thread, part of the reason the ArcGIS terrain is slow here is because the Globe picking (which is used when the camera moves to make sure the camera doesn’t go under terrain)is a bottleneck. There’s an issue for this here: https://github.com/AnalyticalGraphicsInc/cesium/issues/8481
You may be able to get better performance by turning off the camera collision detection:
https://cesium.com/docs/cesiumjs-ref-doc/ScreenSpaceCameraController.html?classFilter=ScreenSpac#enableCollisionDetection
Although I’m not sure if that will turn off the calls to Globe picking.
