I use GeoJsonDataSource to load some polygon and i want to set a outlineWidth of every polygon,but the outlineWidth property of PolygonGraphics is useless,whatever the width set,it shows the same width
Cesium.GeoJsonDataSource.load('./data/data.json').then(dataSource => {
entities.forEach(function(entity,index){
entity.polygon.fill = Cesium.Color.WHITE.withAlpha(0.0001);
entity.polygon.outline = true;
entity.polygon.outlineColor = Cesium.Color.YELLOW;
entity.polygon.outlineWidth = 50;
