WMTS REMOVE/CHANGE
I have used Cesium for a couple days and it is so amazing.Recently I gonna try to load wmts in Cesium and it works fine for me.But when I try to reset/remove/change my first wmts layers to show another one..it doesn't show well. I don't know how to solve it.
var viewer = new Cesium.Viewer('cesiumContainer',{
    Cesium.WebMapTileServiceImageryProvider({
                    url: "http://t0.tianditu.com/vec_w/wmts?service=wmts&request=GetTile&version=1.0.0&LAYER=vec&tileMatrixSet=w&TileMatrix={TileMatrix}&TileRow={TileRow}&TileCol={TileCol}&style=default&format=tiles",
                    layer: "tdtVecBasicLayer",
                    style: "default",
                    format: "image/jpeg",
                    tileMatrixSetID: "GoogleMapsCompatible",
                    show: true
var testProvider1 =new Cesium.WebMapTileServiceImageryProvider({
                url: url+'/geoserver/gwc/service/wmts',
                layer: 'obt:changjian_2016',
                style: '',
                format: 'image/png',
                tileMatrixSetID: 'EPSG:4326',
                tilingScheme:new Cesium.GeographicTilingScheme(),
                maximumlevel: 15,
                tileMatrixLabels : ['EPSG:4326:0', 'EPSG:4326:1', 'EPSG:4326:2','EPSG:4326:3', 'EPSG:4326:4', 'EPSG:4326:5','EPSG:4326:6', 'EPSG:4326:7', 'EPSG:4326:8','EPSG:4326:9', 'EPSG:4326:10', 'EPSG:4326:11', 'EPSG:4326:12', 'EPSG:4326:13', 'EPSG:4326:14', 'EPSG:4326:15'],
                alpha: 1.0,
                show: true
var testProvider2=new Cesium.WebMapTileServiceImageryProvider({
                layer: 'obt:changjian_2016_f',
                style: '',
                maximumlevel: 15,
                alpha: 1.0,
                show: true
function cjtoumingWMTS() {
    viewer.imageryLayers.addImageryProvider(testProvider1)
function cjyingyangWMTS() {
     viewer.imageryLayers.addImageryProvider(testProvider2)
//I use billboard to change wmts layers
//viewer.imageryLayers.removeAll(); removed my glob also,so terrible
Sandcastle.reset = function() {
    viewer.dataSources.removeAll();
    viewer.entities.removeAll();
    viewer.clock.clockRange = Cesium.ClockRange.UNBOUNDED;
    viewer.clock.clockStep = Cesium.ClockStep.SYSTEM_CLOCK;
I have some KML files to show also,when I change,the Sandcastle.reset works fine.
I use viewer.dataSources.add(Cesium.KmlDataSource.load(url, options)) to load kml
and viewer.dataSources.removeAll(); to remove
"version": "1.40.0",
system:win7,
browser:chrome
Hi there,
Instead of adding imagery layers with addImageryProvider and removing all the layers when switching, just add both layers initially and toggle their visibility with ImageryLayer.show.
Gabby
wow. Nice idea.I will try.
