I am working with CZML for the first time, and attempting to animate a series of radar images through a CzmlDataSource object. The animation works fine, but in the latest Chrome there seems to be issues with memory consumption when running the clock at x600 step or higher (memory isn't being released) and an eventual rendering crash/error is observed. Memory consumption is noted on IE Edge and Firefox, but it seems to level off. I was wondering if I'm doing anything wrong with the below CZML structure, or if there's a better approach to what I'm attempting.
My project is actually utilizing the gwt-cs wrapper (https://github.com/iSergio/gwt-cs) maintained by iSergio, and is working pretty well to aid in migrating a legacy app I am working on.
In my viewer, I'm simply calling (JAVA via gwt-cs):
getViewer().dataSources().add(ds.process("/czml/test.czml"));
And my CZML is:
"id" : "document",
"version" : "1.0",
"clock": {
"interval":"2017-09-09T12:00:00Z/2017-09-09T18:00:00Z",
"currentTime": "2017-09-09T12:00:00Z",
"multiplier":600,
"range":"LOOP_STOP",
"step":"TICK_DEPENDENT"
"id" : "radar1",
"name" : "Houston Radar",
"position" : {
"cartographicDegrees" : [-95.07, 29.47, 0.0]
"ellipse" : {
"semiMinorAxis" : 300000.0,
"semiMajorAxis" : 300000.0,
"height" : 0.0,
"outline" : true,
"material" : [ {
"image" : {
"transparent" : true,
"image" : [
"interval" : "2017-09-09T17:00:00Z/2017-09-09T18:00:00Z",
"uri" : "http://data.horizonwx.com/khgx/Base_Reflectivity/1504654708.png"
"interval" : "2017-09-09T16:00:00Z/2017-09-09T17:00:00Z",
"uri" : "http://data.horizonwx.com/khgx/Base_Reflectivity/1504654703.png"
"interval" : "2017-09-09T15:00:00Z/2017-09-09T16:00:00Z",
"uri" : "http://data.horizonwx.com/khgx/Base_Reflectivity/1504654699.png"
"interval" : "2017-09-09T14:00:00Z/2017-09-09T15:00:00Z",
"uri" : "http://data.horizonwx.com/khgx/Base_Reflectivity/1504654694.png"
"interval" : "2017-09-09T13:00:00Z/2017-09-09T14:00:00Z",
"uri" : "http://data.horizonwx.com/khgx/Base_Reflectivity/1504654690.png"
"interval" : "2017-09-09T12:00:00Z/2017-09-09T13:00:00Z",
"uri" : "http://data.horizonwx.com/khgx/Base_Reflectivity/1504654685.png"
My goal is to place multiple ellipses over various locations on the maps, and upon user selection - populate them with ImageMaterial based PNG's that display radar for the area covered. The PNG's are swapped out via a URI change to the ImageMaterial.
OS is Win10 x64 on Chrome Version 60.0.3112.113 (Official Build) (64-bit) on i7 860 w/ 8GB RAM.
