1.47 RuntimeError: Program failed to link. Link log: Could not pack varying v_logZ (1.46=no error)
Okay, reading the Change Log release notes for the 3rd time, here is the culprit:
Paste this “test code” into Sandcastle and run it:
terrainProvider: Cesium.createWorldTerrain()
viewer.scene.globe.depthTestAgainstTerrain = true;
var e = viewer.entities.add({
position : Cesium.Cartesian3.fromDegrees(-122.1958, 46.1915),
billboard : {
image : ‘…/images/Cesium_Logo_overlay.png’,
heightReference : Cesium.HeightReference.CLAMP_TO_GROUND,
verticalOrigin: Cesium.VerticalOrigin.BOTTOM
viewer.trackedEntity = e;
Here’s the same Render error that my page throws:
Note: Additional non-conformant packing restrictions are enforced on D3D9.
Error
at new RuntimeError (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:4361:19)
at createAndLinkProgram (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:99366:19)
at initialize (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:99560:23)
at ShaderProgram._bind (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:99577:9)
at beginDraw (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:173922:23)
at Context.draw (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:173984:9)
at DrawCommand.execute (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:95635:17)
at executeCommand (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:236295:21)
at executeCommands (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:236644:17)
at executeCommandsInViewport (https://cesiumjs.org/Cesium/Build/CesiumUnminified/Cesium.js:237055:9)
I deleted my original post, because there’s no need to wade through my 1100+ lines of code, and the 2 versions of my page,
one of which has been running fine for 2 months, referencing 1.45 and 1.46,
and the other page, which references Cesium v1.47 and throws this render error.
The “minimal example” is the test code posted with https://github.com/AnalyticalGraphicsInc/cesium/pull/6621
4. The Cesium version you’re using, your operating system and
browser.
Cesium 1.46 versus 1.47
Windows 7 Home Premium SP1,
Chrome Version 67.0.3396.99 (Official Build) (64-bit)
I reset Chrome://flags to default, and still get the error on my Windows7 laptop, in Chrome.
I do not get any error testing on my phone, using either Cesium 1.46 or Cesium 1.47
Androids 8.0.0 SM-G930V Build/R16NW
Chrome Version 67.0.3396.87
Could this error be (GPU) hardware-related?
Safari, IPhone iOS 11.2.2, MODEL 6S (A168800),
My page referencing Cesium 1.46 loads fine on the iPhone.
My page referencing Cesium 1.47 throws an ERROR similar to WINDOWS7 LAPTOP & Chrome.
"An error occurred while rendering. Rendering as stopped"
RuntimeError: Program failed to link. Link log: t@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:451:28526 f@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:480:17970 y@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:480:19680 _bind@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:480:20695 G@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:508:918 draw@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:508:4879 execute@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:479:21084 Ge@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:530:16832 Xe@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:530:21311 tt@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:530:26615 $e@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:530:24571 ht@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:531:1320 pt@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:531:1508 render@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:531:9357 render@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:537:18275 t@https://lftgly.com/library/Cesium147/Cesium/Cesium.js:537:11725
Hannah-
Would you please look at this thread?
https://groups.google.com/forum/#!topic/cesium-dev/XlaPQFwjozA
2 days later, after posting on Sunday, no response to
Cesium-dev from the AGI team.
This error is a result of “Improved billboard and
label rendering so they no longer sink into terrain when clamped to ground.”
#6621
It looks like this #6621 update causes render errors for billboards and labels on
some hardware. It broke my working code on 2 out of 3 devices.
Thanks-
-Jon
Hi Jon,
This issue was reported by another user too. I’ve reopened this issue: https://github.com/AnalyticalGraphicsInc/cesium/issues/6793
I wasn’t able to reproduce this myself. What graphics card does your computer have? Can you also paste the results of http://webglreport.com/ ?
Hannah
I believe your case should be fixed in the 1.48 release with https://github.com/AnalyticalGraphicsInc/cesium/pull/6781
There are still some improvements I can make here though.
-Hannah
Here’s the windows laptop WebGLreport:
Platform: Win32
Browser User Agent: Mozilla/5.0
(Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko)
Chrome/67.0.3396.99 Safari/537.36
Context Name: webgl
GL Version: WebGL
1.0 (OpenGL ES 2.0 Chromium)
Shading Language Version: WebGL
GLSL ES 1.0 (OpenGL ES GLSL ES 1.0 Chromium)
Vendor: WebKit
Renderer: WebKit
WebGL
Unmasked Vendor: Google
Inc.
Unmasked Renderer: ANGLE
(Intel® HD Graphics Family Direct3D9Ex vs_3_0 ps_3_0)
Antialiasing: Available
ANGLE: Yes, D3D9
Major Performance Caveat: No
Vertex Shader
Max Vertex Attributes: 16
Max Vertex Uniform Vectors: 253
Max Vertex Texture Image Units: 4
Max Varying Vectors: 9
Best float precision: [-2127,
2127] (23)
Transform Feedback
Coming in WebGL 2
Rasterizer
Aliased Line Width Range: [1,
1]
Aliased Point Size Range: [1,
256]
Fragment Shader
Max Fragment Uniform Vectors: 221
Max Texture Image Units: 16
float/int precision: highp/highp
2127] (23)
Framebuffer
Max Color Buffers: 1
RGBA Bits: [8,
8, 8, 8]
Depth / Stencil Bits: [24,
8]
Max Render Buffer Size: 8192
Max Viewport Dimensions: [8192,
8192]
Textures
Max Texture Size: 8192
Max Cube Map Texture Size: 8192
Max Combined Texture Image Units: 20
Max Anisotropy: 16
Uniform Buffers
Coming in WebGL 2
Supported Extensions:
ANGLE_instanced_arrays
EXT_blend_minmax
EXT_color_buffer_half_float
EXT_frag_depth
EXT_shader_texture_lod
EXT_texture_filter_anisotropic
WEBKIT_EXT_texture_filter_anisotropic
OES_element_index_uint
OES_standard_derivatives
OES_texture_float
OES_texture_float_linear
OES_texture_half_float
OES_texture_half_float_linear
OES_vertex_array_object
WEBGL_color_buffer_float
WEBGL_compressed_texture_s3tc
WEBKIT_WEBGL_compressed_texture_s3tc
WEBGL_debug_renderer_info
WEBGL_debug_shaders
WEBGL_depth_texture
WEBKIT_WEBGL_depth_texture
WEBGL_lose_context
WEBKIT_WEBGL_lose_context
thanks
Hi, we’ve made some improvements that have gone into master, see updates in #6793, can you test against the current master, as linked to in that issue? Thanks!
Gabby & Hannah-
I was not able to test the build last month, but I can confirm that the #6793 changes in the 1.48 release has fixed the rendering error on both the iPhone 6, and the old Win7 laptop’s Intel GPU.
Jon Hall
Awesome! Thanks for checking.
