3D load error using vue cli cesium configuration
**Hello, Im using cesium with vue-cli webpack but at the time I try to load a 3D model it brokes **
**Even I have used this two configurations **
**https://github.com/QingMings/qm-cesium/tree/dev/src/widget/navi **
https://github.com/QingMings/iez-cesium
**appears this warn at first **
./node_modules/cesium/Source/ThirdParty/draco_decoder.wasm
Module parse failed: Unexpected character ’ '(1:0)
You may need an appropriate loader to handle this file type.
(Source code omitted for this binary file)
@ ./node_modules/cesium/Source/ThirdParty ^./.*$
@ ./node_modules/cesium/Source/ThirdParty/xss.js
@ ./node_modules/cesium/Source/Core/Credit.js
@ ./node_modules/cesium/Source/Cesium.js
@ ./src/main.js
@ multi (webpack)-dev-server/client?http://localhost:8080 webpack/hot/dev-server ./src/main.js
I can load simples shapes but when i try to load a 3D model this message appears
RuntimeError {name: “RuntimeError”, message: “Failed to load model: [object Object]↵Unexpected token < in JSON at position 0”, stack: “Error↵ at new RuntimeError (webpack-internal://…e_modules/cesium/Source/ThirdParty/when.js:647:4)”}
hope somebody has any idea what I can do
See my answer in this previous thread.
