Hello, hope you can help me… After struggling so much trying to integrate vue, webpack and cesium I got it thanks to this tutorial https://www.jianshu.com/p/fb237c7eb48c. Thought it was fine because I actually can consume an api and show circles from it but when i try to render the 3D model it got broke… (RuntimeError {name: “RuntimeError”, message: “Failed to load model: [object Object]↵Unexpected token < in JSON at position 0”, stack: “Error↵ at new RuntimeError (webpack-internal://…e_modules/cesium/Source/ThirdParty/when.js:647:4)”})
I’m using this function I got it from the
createModel (url, height) {
// this.viewer.entities.removeAll();
var position = Cesium.Cartesian3.fromDegrees(-123.0744619, 44.0503706, height);
var heading = Cesium.Math.toRadians(135);
var pitch = 0;
var roll = 0;
var hpr = new Cesium.HeadingPitchRoll(heading, pitch, roll);
var orientation = Cesium.Transforms.headingPitchRollQuaternion(position, hpr);
var entity = this.viewer.entities.add({
position : position,
orientation : orientation,
model : {
uri : url,
minimumPixelSize : 128,
maximumScale : 20000
this.viewer.trackedEntity = entity;
this.createModel(’…/…/SampleData/models/CesiumAir/Cesium_Air.glb’, 5000.0);
I want to load 3D buildings on the map, I have tried to load a tile just trying the code from an sandbox example and another error as weird as this was showed so I decided to start by one 3D model. I could say that the error is the webpack configuration because the code it is from the examples but so far I have no idea what else to do or probably the location of the sampleData folder but I actually have placed it in many ways… nothing works
Even I updated the packages, node, npm
“axios”: “^0.18.0”,
“cesium”: “^1.46.1”,
“vue”: “^2.5.2”,
“vue-router”: “^3.0.1”
and I’m using opera as well as chrome on windows 10
Thank you for your help
