I use MicroStation construct one 3D model,then export Collada(dae)file,convert it to gltf by using collada2gltf.exe;but cann't display in webpage,when I used someothers .gltf file,it will be ok,
var model = scene.primitives.add(Cesium.Model.fromGltf({
url : './HKworkTest.gltf',//如果为bgltf则为.bgltf
modelMatrix : modelMatrix,
scale : 10.0
I want to display my 3D model in webpage
1.3 google
