Hi there, Im having issues with my model lining up with my flight path polyline. Why is the model not rendering correctly when vertical exaggeration is higher than 1?
Hi @madison-boman,
Thanks for your post and for being a part of the Cesium community.
Could you possibly reproduce the issue you are seeing using our sandcastle tool? https://sandcastle.cesium.com/ I tried loading your CZML example myself in a sandcastle but I think the file as posted in this thread is incomplete, this is all I am able to see here is this sandcastle example.
Having a working example that reproduces your error will make it much easier for us to understand your issue an work towards a solution.
I hope we can assist shortly.
Luke
Its easy to see the issue if you go to this demo: Cesium Sandcastle
and set viewer.scene.verticalExaggeration = 2;, then zoom out
This is a duplicate of Gltf doesnt scale correctly when Vertical Exaggeration is more than 1
