we are loading the 3d model (glb) using cesium .These models are provided by our clients.
When are loading these models are rendering in different coordinates.
Even when i specify particular location using modelMatrix.
Attached sample file for your reference
var scene = viewer.scene;
viewer.extend(Cesium.viewerCesiumInspectorMixin);
var modelMatrix = Cesium.Transforms.eastNorthUpToFixedFrame(
Cesium.Cartesian3.fromDegrees(-75.62898254394531, 40.02804946899414, 0.0));
var model = scene.primitives.add(Cesium.Model.fromGltf({
url : '/assets/jayanagar.glb',
modelMatrix : modelMatrix,
scale : 200.0
My client wants to load 3d models with shops images
latest version , using chrome browser
It would also help if you explain what you expect the correct position to be, and where they are showing up instead. For example, are they on the different side of the globe? Or just a few meters off? Or is just the orientation that’s incorrect, and the position is correct?
Thanks for providing the sample code. One more thing to test out, can you try uploading the model to cesium.com/ion, and then using the positioning tool (click “Adjust Tileset Location” in the top right after it finishes uploading & tiling) to position it? Let me know if you’re able to get it in the right position visually using that tool.
You should now be able to position the tileset on Cesium ion. This link will take you to the dashboard with a tutorial in the bottom right that will show you how to do that:
