Is there any setting to display 3D Tiles in 2D-View by default?
I have addede my 3D Tilesets. In 3D-View they are shown in WGS and Terrain view. But as sonn as I switch to 2D-View the only thing I can see is the Bounding Box, with no objects in it.
I have b3dm-Files in my Tilesets, showing geological layers. But even if I set the display of the globe in 2D-View to false, I don't see my layers. Maybe I have to look in a simple example on my computer to make it work again.
If you are able to share a Sandcastle using your tileset that’d help a lot. I think the easiest way to do that is to upload it to Cesium ion (https://cesium.com/ion/) which will give you a Sandcastle link that you can just share here. That’ll help a lot when debugging here.
