3D-Tiles ModelMatrix does not work for region??
hi,everyone ,i use cesium3DTile to load my data, code like this:
this.modelLayer = new Cesium.Cesium3DTileset({
url: modelTileSet,
modelMatrix:posMat
modelMatrix works fine for tiles that boundingVolume defined by sphere, model tile is transformed , but when i change my data which boundingVolume defined by region ,modelMatrix does not work.
i view source code of Cesium3DTile.js, find the createBoundingVolume function, about line 842: i wonder why boundingVolumeHeader.region Don’t update regions when the transform changes
Cesium3DTile.prototype.createBoundingVolume = …
else if (defined(boundingVolumeHeader.region)) {
var region = boundingVolumeHeader.region;
var rectangleRegion = Rectangle.unpack(region, 0, scratchRectangle);
if (defined(result)) {
// Don’t update regions when the transform changes
return result;
The transform still applies to the contents of the tile, but just not to the region bounding volume itself. Conceptually since region is specified in cartographic coordinates and the transform is specified in cartesian coordinates it doesn’t really make sense that a region could be transformed.
