about Primitive appearance material
Primitive appearance how to define video material
  // 添加
            scene.primitives.add(new Cesium.Primitive({
                geometryInstances: instance,
                appearance: new Cesium.MaterialAppearance({
                    material: new Cesium.Material({
                        fabric: {
                            type: 'Image',
                           uniforms: {
                                image: 'Images/6.mp4' <-------------------------
Checkout the Video Material Sandcastle example for how it works on the Entity level. You’ll need to pass the uniform an instance of the HTML video element, rather than the video url.
Gabby
Even if you use primitives, you should still be able to create the video material the same way:
var videoElement = document.getElementById(‘trailer’);
                material: videoElement
Gabby
在 2018年6月21日星期四 UTC+8下午9:59:54,Gabby Getz写道:
var videoElement = document.getElementById('trailer');
            appearance: new Cesium\.MaterialAppearance\(\{
Gabby
On Tuesday, June 19, 2018 at 8:52:48 PM UTC-4, xypi...@126.com wrote:在 2018年6月19日星期二 UTC+8下午10:56:59,Gabby Getz写道:
> Checkout the Video Material Sandcastle example for how it works on the Entity level. You'll need to pass the uniform an instance of the HTML video element, rather than the video url.
> Thanks,
> Gabby
> On Monday, June 18, 2018 at 10:57:14 PM UTC-4, xypi...@126.com wrote:Primitive appearance how to define video material
> // 添加
> fabric: {
> type: 'Image',
> uniforms: {
Thanks,but i want use "primitives" add rectangle,not use "entities" add rectangle.because "entities" not "modelMatrix" interface. my english very bad - -!
TypeError: this.material.isTranslucent is not a function
    at p.s.isTranslucent (http://localhost:51309/Build/Cesium/Cesium.js:495:12163)
    at V.update (http://localhost:51309/Build/Cesium/Cesium.js:501:12716)
    at a.update (http://localhost:51309/Build/Cesium/Cesium.js:540:20000)
    at tt (http://localhost:51309/Build/Cesium/Cesium.js:544:3341)
    at Ke (http://localhost:51309/Build/Cesium/Cesium.js:544:1145)
    at Ze (http://localhost:51309/Build/Cesium/Cesium.js:544:731)
    at Qe (http://localhost:51309/Build/Cesium/Cesium.js:543:31164)
    at lt (http://localhost:51309/Build/Cesium/Cesium.js:544:7171)
    at ut (http://localhost:51309/Build/Cesium/Cesium.js:544:7339)
    at we.render (http://localhost:51309/Build/Cesium/Cesium.js:544:15524)
                releaseGeometryInstances: false,
                show: true,
                show: true,
                show: true,
Gabby
> Thanks,
> Gabby
> // 添加
> fabric: {
> type: 'Image',
> uniforms: {
                show: true,
showRenderLoopErrors : false,
shouldAnimate : true
var scene = viewer.scene;
var instance = new Cesium.GeometryInstance({
geometry : new Cesium.RectangleGeometry({
rectangle : Cesium.Rectangle.fromDegrees(-100.0, 20.0, -88.0, 28.0),
vertexFormat : Cesium.PerInstanceColorAppearance.VERTEX_FORMAT
var material = Cesium.Material.fromType(‘Image’);
material.uniforms.image = videoElement;
material.uniforms.repeat = new Cesium.Cartesian2(1.0, 1.0);
geometryInstances : instance,
appearance : new Cesium.MaterialAppearance({
material : material
You’ll probably need to play with the shape and repeat values.
The problem has been solved, thank you very much. love u love u kiss kiss
在 2018年6月27日星期三 UTC+8下午10:09:01,Gabby Getz写道:
