I am using ol3-cesium for 2D and synching of vector features between Openlayers (2D) and Cesium (3D).
Ol3-Cesium makes use of primitives and groundPrimitives instead of entities. However, i would like my primitives to have the same "look" as entities.
If I compare for example:
(the 5 boxes above eachother -translucent or solid )
with
(include some extrusion)
They appear very different..
I tried tweaking around with the PerInstanceColorAppearance settings based on https://cesiumjs.org/tutorials/Geometry-and-Appearances/, but I just dont seem to be able to approach these 5 boxes from the first example- which are created as entities.
Anybody knows how I can get the same look with primitives?
However, unless you have a good reason, I would recommend using the Entity API instead of the Primitives API because it handles a lot of things like setting the correct vertexFormat and material properties for you.
Thanks a lot for your quick reply, with the example I figured out the right settings on Primitive, GeometryInstance and Appearance!
I had found the current Geometry&Appearance (based on entities) example in the sandcastle but its good to know that in the dev folder the legacy examples are still contained.
