access_token has a time limit?
Does token have a time limit? My token expired two weeks ago. I’ve reproduced it. I don’t know if it will expire
Your own Cesium ion token should not expire, unless you deleted it in your Cesium ion account. If you’re using the default token that comes with CesiumJS, then we do revoke the old tokens with each new release since those are only meant for testing.
