I followed this link (申请cesium的token并使用_MYNAMEL的博客-CSDN博客), but i can’t create token , the page says that ‘No authorization token was found’. Shoud I do someting before creating token?
PS: I sign in Cesium by the Github account.
Thanks!
Hi
This is very strange indeed. One of the main ways this could happen is you signed out of ion in one tab and then switched to this tab without refreshing and tried to create a token.
The only other possible explanation would be if something is interfering with your network (like company network settings or browser extensions).
It would be best to sign out and sign in again, try a different browser with plugins disabled.
Can you also share the Browser and OS you are using?
