All of a sudden my Cesium started to stop working and when I try to recreate a token it says this :
Hi @el_luchador, welcome to the community!
It looks like you already assigned a default access token to your project. So all you need to do is click the top button, “Authorize the project default token to access this asset”. Basically you’re letting the token have access to that tileset, so that it can stream it at runtime.
If you want to use a different token, you can visit Cesium ion to create a separate one, then paste it in the Ion Access Token setting in your tileset.
Let us know if that helps!
