Add billboard in 3D scene with terrain
Hi
I’m trying to add a 3D marker with the terrain loaded, but something strange is happening.
When I double click the marker is added displaced and not over where I have the cursor.
I think I’m using the ellipsoid without terrain or I don’t know, because the displacement isn’t uniform.
Any suggestions?
  • Add Double Click Coordinates.
scene.globe.depthTestAgainstTerrain = true;
canvas.addEventListener(‘dblclick’, function(e) {
if (viewer.entities.values.length > 1) {
clearCanvas();
mousePosition = new Cesium.Cartesian3(e.clientX, e.clientY);
var ray = scene.camera.getPickRay(mousePosition);
var pickedPosition = scene.globe.pick(ray, scene);
if (pickedPosition) {
pinBuilder = new Cesium.PinBuilder();
url = Cesium.buildModuleUrl(marker_pin);
Cesium.when(pinBuilder.fromUrl(url, Cesium.Color.RED, 80), function(canvas) {
viewer.entities.add({
position: pickedPosition,
billboard: {
image: canvas.toDataURL(),
verticalOrigin: Cesium.VerticalOrigin.BOTTOM,
heightReference: Cesium.HeightReference.CLAMP_TO_GROUND,
disableDepthTestDistance: Number.POSITIVE_INFINITY
if (viewer.entities.values.length === 2) {
getRoute()
} else {
console.log(‘Globe was not picked’);
}, false);
I think scene.globe.pick may be returning the ellipsoid position. Try using scene.pickPosition:
https://cesiumjs.org/Cesium/Build/Documentation/Scene.html#pickPosition
This will take in a 2d window position directly. If this doesn’t work, can you recreate the issue in a Sandcastle example (https://cesiumjs.org/Cesium/Apps/Sandcastle/index.html) and share it here? That way I can easily reproduce the issue.
Amazing! fixed using
scene.pickPosition.
the final code is:
clearCanvas();
var pickedPosition = scene.pickPosition(ray, scene);
billboard: {
getRoute()
} else {
}, false);
