Mouse_MOVE with billboards not working
I want to show altitude like "Pick position"
Here is my code. I have used billboards to show icons but I am getting this erro - Uncaught TypeError: Cesium.Cartographic.fromCartesian is not a function
                     var pinBuilder = new Cesium.PinBuilder();
                   var bluePin = viewer.entities.add({
                       position : Cesium.Cartesian3.fromDegrees(coordinates_array[0],coordinates_array[1]), //log1+","+lati1
                       billboard : {
                           image : pinBuilder.fromText(icon_name,Cesium.Color.fromRgba('0x'+flight_color_code).withAlpha(0.5), 48).toDataURL(),
                           verticalOrigin : Cesium.VerticalOrigin.BOTTOM
                   var scene = viewer.scene;
                   var handler;
                   if (!scene.pickPositionSupported) {
                       console.log('This browser does not support pickPosition.');
                   var labelEntity = viewer.entities.add({
                       label : {
                           show : false,
                           showBackground : true,
                           font : '14px monospace',
                           horizontalOrigin : Cesium.HorizontalOrigin.LEFT,
                           verticalOrigin : Cesium.VerticalOrigin.TOP,
                           pixelOffset : new Cesium.Cartesian2(15, 0)
                   // Mouse over the globe to see the cartographic position
                   handler = new Cesium.ScreenSpaceEventHandler(scene.canvas);
                   handler.setInputAction(function(movement) {
                       var foundPosition = false;
                       if (scene.mode !== Cesium.SceneMode.MORPHING) {
                           var pickedObject = scene.pick(movement.endPosition);
                           if (scene.pickPositionSupported && Cesium.defined(pickedObject) && pickedObject.id === bluePin) {
                               console.log(pickedObject.id,"----------------------");
                               var cartesian = viewer.scene.pickPosition(movement.endPosition);
                               if (Cesium.defined(cartesian)) {
                                   var cartographic = Cesium.Cartographic.fromCartesian(cartesian.position);
                                   var longitudeString = Cesium.Math.toDegrees(cartographic.longitude).toFixed(2);
                                   var latitudeString = Cesium.Math.toDegrees(cartographic.latitude).toFixed(2);
                                   var heightString = cartographic.height.toFixed(2);
                                   labelEntity.position = cartesian;
                                   labelEntity.label.show = true;
                                   labelEntity.label.text =
                                       'Lon: ' + (' ' + longitudeString).slice(-7) + '\u00B0' +
                                       '\nLat: ' + (' ' + latitudeString).slice(-7) + '\u00B0' +
                                       '\nAlt: ' + (' ' + heightString).slice(-7) + 'm';
                                   labelEntity.label.eyeOffset = new Cesium.Cartesian3(0.0, 0.0, -cartographic.height * (scene.mode === Cesium.SceneMode.SCENE2D ? 1.5 : 1.0));
                                   foundPosition = true;
                       if (!foundPosition) {
                           labelEntity.label.show = false;
Not sure where is the error.
Thanks
I can’t seem to recreate this error. Can you share an example I can run in Sandcastle? Just click on “Share” and then paste the link you get here.
If you can also post the full error message (including the stack trace) that’d help. What version of Cesium are you using?
