Does anyone have any advice about the best way to add an 2.5D data overlay to the map (e.g. a visualization with a z coordinate per pixel, creating a terrain or 3D model)? For example, you can imagine a heatmap where intensity is also elevation. Should this be a custom graphical primitive added to the map, or would it need to be converted into the terrain format, or is there another approach that would be best?
I think it should be pretty straightforward to do this by writing a custom TerrainProvider whose requestTileGeometry method returns and instance of HeightmapTerrainData. You’ll be representing your surface as terrain, but you don’t need to conform to Cesium’s terrain format in order to do so.
Thanks for your idea. I am a beginner on Cesium, what I want to do is to create a heatmap layer from my custom data. I was wondering if you could give an example of creating a custom TerrainProvider? Thank you very much.
Thanks for reply! I am trying to use SimplePolylineGeometry, here is my modified code from the sandcastle:
var testPositions = ;
var testColors = ;
//draw heatmap in the range of upper left (-77.381, 38.983) to lower right (-76.892, 38.864)
for(var i=-77381; i < -76892; i++){
for(var k=38983; k > 38864; k--){
testPositions.push(Cesium.Cartesian3.fromDegreesArray([
i/1000.0, k/1000.0,
(i+10)/1000.0, (k+10)/1000.0
testColors.push(Cesium.Color.fromRandom({alpha : 1.0}));
var testpolyline = new Cesium.GeometryInstance({
geometry: new Cesium.SimplePolylineGeometry({
positions: testPositions,
colors:testColors,
followSurface: false
