Adding New CZML DataSources w/o Removing Existing Data
I have a drop down toolbar that allows the user to select CZML files to add to Cesium. When the user selects one DataSource and then selects a different DataSource, the latter overwrites the first DataSource selection, i.e. removes it.
How can the user select both of the CZML datasources without removing any existing data?
Thank you!
Sandcastle.addToolbarMenu([{
text : ‘Basic’,
onselect : function() {
text : ‘blah’,
var dataSourcePromiseS = Cesium.CzmlDataSource.load(czmlS);
viewer.dataSources.add(dataSourcePromiseS);
text : ‘Last 30’,
var dataSourcePromise30 = Cesium.CzmlDataSource.load(czml30);
viewer.dataSources.add(dataSourcePromise30);
}], ‘toolbar’);
Also, the following does not work even when dropping CZML files in. However, I would like to do this via code.
viewer.extend(Cesium.viewerDragDropMixin, { clearOnDrop : false });
By default, Sandcastle will not remove anything when you select the different items. If you used an example like this as a reference:
Sandcastle.reset = function() {
viewer.dataSources.removeAll();
viewer.clock.clockRange = Cesium.ClockRange.UNBOUNDED;
viewer.clock.clockStep = Cesium.ClockStep.SYSTEM_CLOCK;
Specifically, the dataSources.removeAll() function is what clears the previous data.
Notice the Sandcastle.reset function defined at the bottom:
