CZML datasource load function does not clear existing datas
I'm using Cesium to display a live race runner's datas. I would like to update runner's datas using CZML datasource. For my use case, I need previously existing datas to be totally cleared before update.
The problem I'm facing is that CzmlDataSource->load() function does not clear existing datas as it is declared in the documentation: "Loads the provided url or CZML object, replacing any existing data.".
Problem can be reproduced pasting this code in sandcastle app:
var czmlPacket1 = [
        "id" : "document",
        "version": "1.0"
        "id" : "point",
        "name" : "Test point - packet 1",
        "point" : {
            "color" : {
                "rgbaf": [1, 0, 1, 1]
            "pixelSize": 40
        "position": {
            "cartographicDegrees": [1, 60, 1000]
var czmlPacket2 = [
        "id" : "document",
        "version": "1.0"
        "id" : "point",
        "name" : "Test point - packet 2",
        "point" : {
            "color" : {
                "rgbaf": [1, 1, 0, 1]
            "pixelSize": 20
        "position": {
            "cartographicDegrees": [2, 40, 1000]
var dataSource = new Cesium.CzmlDataSource();
dataSource.load(czmlPacket1).then(function ()
    window.setTimeout(function ()
        dataSource.load(czmlPacket2).then(function ()
            console.log('packet 2 received, but dot hasn't been updated: color and position did not change.');
    }, 2000);
viewer.zoomTo(dataSource);
I need to do this to transparently update datas providing a live race preview.
I've tried using "process()" method instead of "load()" but I'm working with path estimated positions which are no longer valid when next update is made, so I really need to clear existing datas.
I found 2 workarounds for this:
- deleting datasource and creating a new one works, but this automatically reset my cusomized clock and timeline and I need to re-set it every time I update datas
- deleting datasource entities before calling load works but existing datas disappear while expecting request response
Cesium 1.39, Windows 10, Chrome
I can confirm that this is an existing bug:
https://github.com/AnalyticalGraphicsInc/cesium/issues/3577
I’ve updated the issue with additional information and a link to this thread.
