I make a skin character model in blender 2.8, and export it to gltf. When I load the model into Cesium, it throw errors like below
But I can view the model in Babylon.js and three.js viewer in VS Code, and play the animation.
After debug I found the error is because the gltf skins have no skeleton property, so the code throw error in Model.js:
var skin = gltfNode.skin;
if (defined(skin)) {
skeletonIds.push(skins[skin].skeleton);
It is a commonly need for animated model exported from Blender to be visualized in Cesium.
Cesium 1.60
Windows10
Chrome 75.0.3770.142
character.zip (827 KB)
