Animation and CZML
I have a time series with lat/lon/alt that I am converting to CZML.
How do I enable the animation to play an aircraft back against the time parameters?
Robert
Hi Robert,
Here’s a good overview of loading and styling entities you load in with data sources like CZML.
Something like this should work:
var czml = [{
"id" : "document",
"name" : "CZML Point - Time Dynamic",
"version" : "1.0"
"id" : "aircraft",
"availability" :"2012-08-04T16:00:00Z/2012-08-04T16:05:00Z",
"position" : {
    "epoch" : "2012-08-04T16:00:00Z",
    "cartographicDegrees" : [
        0,   -70, 20, 150000,
        100, -80, 44, 150000,
        200, -90, 18, 150000,
        300, -98, 52, 150000
"model": {
    "gltf" : "../../SampleData/models/CesiumAir/Cesium_Air.glb",
    "scale" : 2.0,
    "minimumPixelSize": 128
var dataSource = viewer.dataSources.add(Cesium.CzmlDataSource.load(czml));
dataSource.then(function(dataSource){
var aircraft = dataSource.entities.getById('aircraft');
aircraft.orientation = new Cesium.VelocityOrientationProperty(aircraft.position);
Thanks!
Gabby
Whoops, forgot to include the link to the tutorial: https://cesiumjs.org/tutorials/Cesium-Workshop/#loading-and-styling-entities
