I need to use an ArcGisMapServerImageryProvider where the format query parameter is png32.
The hard coded format in the code seems to be png. See: https://github.com/AnalyticalGraphicsInc/cesium/blob/1.59/Source/Scene/ArcGisMapServerImageryProvider.js#L265
If I add format to the resource queryParameters it is ignored due to the above code. I would have expected you could override the 'default' queryparam values with queryparams in resource?
Try changing the format used here: https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/?src=ArcGIS%20MapServer.html
The png data for this MapServer (non-public, or I'd link it) is not valid, but the png32 data works perfectly.
1.59
