Unfortunately the .dae source is not available - any chance of making that public? I want to excise the rocket flames to reuse as hot air balloon burners.
However, unfortunately the license for the models doesn’t allow for them to be used outside of STK. You may need to create your own texture for your balloon model.
I’m fairly certain everything that ships with CesiumJS is under the same license, Apache 2.0, except for anything third party that has its own license as described here:
