Assets path in webpack compiled Cesium
I successfully followed this tutorial https://cesiumjs.org/tutorials/cesium-and-webpack/ .
Where we copy the static assets, such as "Assets", webpack puts the Assets into js/mycesium/Assets, which is correct. This is my modification to the tutorial.
CODE FROM webpack.config.js:
CopywebpackPlugin([ { from: path.join(cesiumSource, 'js/mycesium/Assets'), to: 'include/olcs-1.0/Assets' } ]),
However, inside the compiled app.js, the paths to Assets/ is still off the top level root. The browser is throwing 404 not found on all the assets.
I'm doing this because I will have several different apps that will use the same mycesium build (app.js). Assets, Workers, and Widgets will not live on the same level as index.html They will be in <context_root>/js/mycesium/
The question is, how to reflect these paths in the compiled js file?
Thanks in advance for any pointers!
Hi there,
When you define the base path with:
new webpack.DefinePlugin({
// Define relative base path in cesium for loading assets
CESIUM_BASE_URL: JSON.stringify(’’)
Instead of an empty string, provide the path you would like to use, relative to the Cesium source, at which you are loading you Assets, Workers, and Widgets.
Thanks!
Gabby
