We have a system that captures touches from an external source and then dispatches them to a Cesium viewer to manipulate the map. The touches are dispatched after a synthetic pointer event is created with new PointerEvent(). When the new event is dispatched to the viewer, Cesium calls setPointerCapture on pointerdown events – in Chrome, this throws an error (“No active pointer with the given id is found”), since (we think…) the event was not organically created by a mouse click or touch, but from instantiating PointerEvent().
What do think is the best way to avoid this error? We’d like the external touches to execute a zoom feature that’s already built-in. Do you think we should reroute the PointerEvent and rebuild the zoom functionality using Camera.zoomIn/zoomOut?
HI @rdkelley8,
Thanks for your post and welcome to the Cesium community.
Based on the information you provided, I think the problem you identified regarding Cesium not handling the pointer events in Chrome would require some investigation as a possible bug. Would you mind creating an issue in the Cesium repo with the information you provided above and any additional information that would be helpful? GitHub · Where software is built It would also be very helpful for investigating and debugging if you could provide sample code reproducing the issue in our sandcastle tool https://sandcastle.cesium.com/.
Because this issue requires investigation, if it is not too difficult based on the desired behavior of your feature I think the solution you proposed to reroute the PointerEvent and rebuild the zoom functionality using Camera.zoomIn/zoomOut would be a good path forward.
Please let us know about creating an issue in the Cesium repo and if you have further questions.
Luke
Thank you, Luke. I’ll try to reproduce in a sandbox and open up an issue.
