Hello everyone, I’m working on a project but there is a problem about the ellipsoid baseLayer
As you can see below, since I pulled the map from Bing it works without any problem online, But I know that this solution will not work on offline because i pull the map with an API key support… and i need to work on offline
In this way, even though I use createWorldImagery or createTileMapServiceImageryProvider below, the map ellipsoid either does not appear at all, or I just see it as a black screen without the overlay loading. I will also transfer the outputs.
useEffect(() => {
const viewer = new Viewer("cesiumContainer", {
imageryProvider: createWorldImagery(),
useEffect(() => {
imageryProvider: createTileMapServiceImageryProvider({
url: Cesium.buildModuleUrl("Assets/Textures/NaturalEarthII")
As you can see, what I actually want to do is a very basic and simple thing. I have never encountered a similar problem in my previous works, but I cannot overcome it now.
Thanks in advance for your help
