Billboard only render once when map init in 2d with terrain data. Billboards added later won't render unless manually zoom in/out.Adding billboard works fine when map is in 2d with no terrain data or 3d.
var bc = viewer.scene.primitives.add(new Cesium.BillboardCollection({
scene: viewer.scene
bc.add({
position:Cesium.Cartesian3.fromDegrees(longitude,latitude);
image: url/to/image
heightReference: Cesium.HeightReference.CLAMP_TO_GROUND
// code above works fine when excute when map init.
// it will creat a billboard object but won't be rendered on map after map
// initialized
Is there a way force billboard added after map initialized to render without zoom in/out?
Cesium 1.38
win10
chrome 61
