I noticed that when I create a billboard, and set the map to be either 3D or Columbus view, and then rotate the map from a touch screen, the billboard rotation is not steady, it changes the heading.
What I need is that when the user rotates the map, the billboard heading will not change at all.
I tried using allignedAxis property around x or y, it is better but still rotating.
How can I set the billboard rotation to not get affected by the map rotation?
Thanks.
Can anyone provide an answer on this issue?
Thanks a lot.
Hi there,
You’re right in that using AlignedAxis is the way to approach this problem, but unfortunately we have a small bug. See the open issue here: https://github.com/AnalyticalGraphicsInc/cesium/issues/2487
I’ve linked to this forum post so that we can notify you when we get a chance to fix this.
Update - the bug mentioned before (https://github.com/AnalyticalGraphicsInc/cesium/issues/2487) has been successfully fixed! The fix will be available in the next release.
Joe
