Controlling axis of rotation for a billboard
Is it possible to control how a billboard is rotated. If I use the 'alignedAxis' then assuming the billboard has the default horizontal and vertical alignment at the center then billboard rotates as expected as I rotate the globe. However, if I have the vertical alignment set to 'BOTTOM' the billboard no longer rotates about it's geolocated position
Hi Tony,
I think alignedAxis is the correct way to accomplish this, we just need to figure out what the correct value to set this property to. How exactly do you want the billboard to rotate? Do you have an image that shows what you’re looking for by chance?
Gabby
