Bug in BuildApps starting from 1.20?
Hi cesium forum,
I have successfully built my cesium application following the build guide (https://github.com/AnalyticalGraphicsInc/cesium/blob/master/Documentation/Contributors/BuildGuide/README.md) until some days ago. Then I upgraded to the last github cesium version and my Apps is no longer usable.
I have tried to build the default Cesium Viewer Application and the same error is thrown out by the Web Console.
Error: Script error for: CesiumViewerStartup
http://requirejs.org/docs/errors.html#scripterror
Apparently CesiumViewer.css and CesiumViewerStartup.js are no longer copied to the Build/Apps/CesiumViewer directory.
Cesium behavior has changed between releases 1.19 and 1.20
Is that supposed to happen? I have to run some new command to have Apps working?
Thanks for any help!
Chiara
Hello Chiara,
Did you pull the latest code from GitHub? I tried to reproduce this is master and found that everything worked correctly.
Hannah
Hello Hannah,
my problem came up after a run clean…
Today I have started from the beginning
$ git clone GitHub - CesiumGS/cesium: An open-source JavaScript library for world-class 3D globes and maps 🌎 cesium-agi
$ cd cesium-agi/
$ npm install
$ npm run build
$ npm run minify
$ npm run buildApps
$ ls Build/Apps/CesiumViewer/
Assets favicon.ico Images index.html require.js web.config Widgets
CesiumViewerStartup.js is not in the Apps directory…
If I run “npm start” the built version give me the error
Common Errors
Am I missing some step?
Chiara
Hi Chiara,
Hmm, very weird. I just ran through the exact same steps that you posted and got this:
Assets/ favicon.ico require.js Widgets/
CesiumViewer.css Images/ ThirdParty/ Workers/
CesiumViewerStartup.js index.html web.config
What OS do you have?
-Hannah
Oh also, what version of node do you have? Using an old version of node could cause problems too. We recommend using 4.0 or later.
-Hannah
Hello Hannah,
I’m on Fedora22, with node installed via fedora repo.
I have uninstalled the repo version and installed the 4.4.5 version from https://nodejs.org/
That fixes the problem!
Thanks a lot for your help and your time!
Chiara
