Bug related to Extruded Height
Good afternoon,
I found a bug / issue using Extruded Height with Polygon
I created a SandCastle example in order to show the issue at this Link.
While the polygon has not Extruded Height it is drawn perfectly, but with the parameter assigned a new line appears.
Best Regards.
Emanuele
Hi @TheSarge81an1, I took a look at your sandcastle but I’m not sure what part is the “new line” you’re describing. Can you provide a picture showing the issue you’re seeing?
My best goes is you mean the chunk that shows up on the “top” across the water. I think that’s because of an extra point in the polygon but I’m not positive and didn’t dig too deep yet
