Hello , I am trying to build terrains in quantized-mesh format for cesium using
Generally it is working fine, no issue at all. But if I build multiple srtm files , there is a gap between these 2 files.
For example , If i generate for N51W001.hgt and N51W002.hgt , there are duplicate terrains for each sources as they are adjacent like
N51W001/13/8146/6462.terrain
N51W002/13/8146/6462.terrain
When ctb-tile overrides N51W001 when generating N51W002 , it replaces file N51W001/13/8146/6462.terrain and makes a big hole. If I don’t override it, there are holes on the other side. I have attached an image of the real issue.
I completely understand you might not support cesium terrain builder , however that will be helpful if you could advise how cesium or others build their terrain using multiple SRTM files. Any suggestion or advice would be great.
Regards,
David
